Straighter cuts on Rubi
Used to do as above for same reasons but as I'm tiling a lot of bathrooms with same tiles on walls and floor I find it easier to tile floor first then tile off of the floor to ensure grout joints line up .
Thanks Simon.
Yes was thinking along similar lines. Its only a pressed steel bed on the Rubi, so may deflect a tad. I've got the latest snapper in it and it generally cuts well...but I did have a go on a Monty which I liked and also a Sigma. Probably better suited to big porcelain, but can't quite justify one yet 🙂
No deflection on this one
Get a piece of wood and mark and cut wood so that it just sits between rails at front of cutter, then try all along rails to see if it is tight or loose, turn rails until wood is exactly same all the way along then tighten everything up.
Chris N,
Dumbo,
Chris N,
Dumbo,
