Running 230V well pump from 115V generator? Discussion ThreadRunning 230V well pump from 115V generator? Electrical Advice
I have a 115V Honda inverter generator that can put out 2200 watts. My well pump is 1/2 hp, which should be well within that power requirement, but is 230 volts. Can I simply install a step-up transformer to run the pump off my generator?
Running 230V well pump from 115V generator? for the original thread on Electricians Forums
