s plan 8 zone ufh diagram? Electrical Advice
s plan 8 zone ufh diagram? Discussion Threads plan 8 zone ufh diagram? Electrical Advice
as part of a re wire the house is having underfloor heating, via the boiler.
having spoken to the plumber he says they are going to be using a john guest 8 way mains voltage system
John Guest Speedfit - The World Leader in Push-fit Fittings, Pipe and Plastic Plumbing Systems - Mains Voltage System - Controls
hes told me they are having 4 stats on the ground floor, and one on the 1st floor landing for the radiators (its a 3 storey house with ufh only going on the ground floor, radiators on the rest)
its an s plan system, but im struggling to find a diagram anywhere of how to include a ufh system into a normal s plan, especially with 5 stats.
the only thing hes told me is that i need to supply a fused spur to the boiler/wiring center, and need to wire from there.
the last time i did an s plan was on my am2 18 months ago. i appreciate its easy enough with just heating and dhw, but when including a ufh system as well.
im assuming that it will be the same, and the water supply to the 8 zone ufh manifold will effectivly be the same as the one for the radiators and the manifold valves will controll it from this point??
also and this is most urgent really, on a mains voltage system does anyone know what cables to run to the stats? 1.5mm 3c+e? or a normal twin?
any help will be greatly appreciated, thanks matt
s plan 8 zone ufh diagram? for the original thread on Electricians Forums
Electrical Advice
Lou,
Lou,
