Sbr Instead Of Tanking?
That would require the SBR to be applied neat, that would form a skin and that would worry me.
majority of tanking products are 90% sbr 10% paste I am lead to believe.
I disagree with this.
SBR (Styrene-butadiene or styrene-butadiene rubber) has never featured in any tanking products I have ever used.
I have picked Mapei WPS mapegum as one example-
Broken Link Removed
It details the chemical composition to the letter and it features nowhere. It is made up of numerous synthetic complex polymers but no SBR.
Even if sbr was waterproof, which I'm not convinced it is, there's still the issue of taping corners and joints and I'm not sure I'd want to trust sbr and Silicon versus a proper tanking set up.
SBR was developed by the germans prior to ww2 as a synthetic alternative to rubber and is still used today in the tyre industry. it is also used in damp proofing damp rooms or surfaces were it is painted on to form a seamless damp proof liner . the main component in any tanking solution is SBR AS IT is resistant to emusifacation ,flexible and very durable.
all tanking products are a skin of some sorts and that what worries me also. I don't use tanking products as ive said in the past I use membrains which I attatch to the walls using tilemasters ultimate s2 addy . and believe me its a ***** to pull off.
ordered a tanking kit today to put on my hardibacker covered bath/shower but am left wondering if ive made a mistake?
i popped into a tile shop tonight and the guy there said why didnt i just paint it with £9 SBR as not only is it a primer, it waterproofs too!!!
comments appreciated
Go back in tomorrow and throw a full 5lt of SBR at his head
I used to always use the Ardex wpc tanking kits......basically a tub of sbr a small bag of rapid set grey and a roll of plasterers skrim.
I've protected my block and beam patio floor over the winter with sbr and cement slurry, not a drop has seeped through to the storage area underneath, I am beginning to think spending £400 on a Mapei tanking system will be a waste of money and I should just give it a couple more coats of sbr/cement slurry.
talk to the experts at sovereign chemicals that is exactly what they would recommend
Broken Link Removed
numerous synthetic polymers. could these polymers be stryrene butadiene and rubber or sbr?
I used sovereign chemicals when I tanked the walls in my cellar, there was a specific product they sold for it that you mixed with water after sandblasting and applying anti sulphate to the walls then you mixed sbr and cement to a thick paste and formed a 1 inch angled fillet to all internal corners, better than having the wall linings and a sump pump as with some systems.
Tanking and Wetrooms
gooty,
Qwerty,
gooty,
Qwerty,
