Mossop
I was watching a film on Youtube about installing a Schluter Kerdi-Board wall beside a bath. You will notice from the attached picture that the installer is about to install a Kerdi-Board from the bath up.
Do you think it would be okay to install the Schluter Kerdi-Board wall first from the floor up to the ceiling, then install the bath, then tile from the bath up? That way, it means the 19mm thick Kerdi-Board will provide acoustic insulation below the level of the bath lip.
However, I suppose by doing this it would be difficult/impossible to install a horizontal supporting beam along the underside of the bath as can be observed in the photo (attached to the studs).
Thanks.
Thanks.
