Discuss Screed with central heating pipe duct in the UK Tiling Forum area at TilersForums.com.
Jackswan
Just after some advice on what adhesive to use.
Screed laid about a year ago and running across it is a duct which carry the central heating pipes. Duct is made of external grade ply with a screwed down cover. It's roughly 125 mm wide and 2.5 metres long. Totally forgot about the duct until I lifted the hardboard protecting the floor tonight.
Porcelain tiles 500 x 500 are being laid on the screed and I have been provided with Tilemaster Rapid set adhesive. Should I use a flexible adhesive where the tiles run across the ducting?
Just another question should the screed be primed with anything first before laying the adhesive?
Any advice would be welcome.
Cheers
Jackswan
Ok I now see what is meant by an uncoupling membrane.
Also in the floor screed is a double seal inspection cover set at the correct height for tiles. If I was to fit this membrane the surface of the screed I assume would rise above the height of the inspection cover.
Above is a photo of the duct and the position that the tiles will take across it.
Jackswan
Thanks whitebeam, sounds good.
Just reading a posting on this forum
cracking screeds/tiles and underfloor heating
about cracks in screeds and how to repair them before tiles are fitted.
Using PCI PECILASTIC which apparently is only 0.8mm thick, but is it any good? This would be a good solution if it could just be laid say 6 inches either side of the ducting.
Where would I be able to obtain some of this from if it was suitable?
Reply to Screed with central heating pipe duct in the UK Tiling Forum area at TilersForums.com
Hello Everyone, I am new to this forum and I'm looking for your experts' advice in a situation...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
