Discuss screw through pipes ?? in the UK Tiling Forum area at TilersForums.com.
I only use it if I dont know what is under there and there are absolutely no other options left. You could always buy one of these........
SNAKE VISION ENDOSCOPE INSPECTION CAMERA SEESNAKE 10mm | eBay
Im buying one soon and Im sure will save the stress & worry :hurray:
do you not screw the backer board down? (as well as adhesive) and the op said the pipe was hit due to the floorboards being screwed down to prevent deflectionI would use 10mm backer board on floorboards and I would never use screws so I wouldn't have the problem
Always screw to boards down but at the edges of the board the pipes shouldn't be in the middle but when boards have been taken up to relay pipes the should be screwed so would lift a couple and check the where the pipes godo you not screw the backer board down? (as well as adhesive) and the op said the pipe was hit due to the floorboards being screwed down to prevent deflection
That's got confused no I don't screw backer board down just floor boardsAlways screw to boards down but at the edges of the board the pipes shouldn't be in the middle but when boards have been taken up to relay pipes the should be screwed so would lift a couple and check the where the pipes go
Why would you ? I wouldn't screw the tiles down
Reply to screw through pipes ?? in the UK Tiling Forum area at TilersForums.com
