Discuss sealing concrete floors in the British & UK Tiling Forum area at TilersForums.com.
demondaxs
hi guys,
working over here in cyprus, and the major fault is tiles lifting with the heat, 30-45 degrees in the summer, the tilers don't seem to seal the floors, at the moment i'm useing goldstar pva, as a sealer, they seem to be ok, i've done quite a few jobs with no problems so far, any thoughts on anything better, and we don't have the benefit of all the materials that you guys have..
regards demon
So their you go PVA a no no their is plenty of info on why not to use it on this site. What makes of addy do you get out there? Here in Spain we work with similar temps in the summer but our addy is designed to cope with it it tells you no need to dampen down only in exceptional circumstances which is normaly wind drying things to quick. Good quality cured conc shouldnt need priming but if it does follow the makers instructions. perhaps some of our Aussi friends can help us out on this one.
Lucius
Reply to sealing concrete floors in the British & UK Tiling Forum area at TilersForums.com
Need some advice please on sealing Slc. Not sure if I'm in the right place for this but worth a...
hmtiling
H
Hi all, I'm not much of a forum poster, and am also new here to this one. Additionally, in...
6K
GoneGuy
My bathroom is on the ground floor of my circa 1900 end of terrace house in Sussex. It had lino...
34K
J Sid
Hi guys I am after a bit of advice. I have spent some time reading through posts but it all...
5K
I am tiling a wet room that will have pitted and porous 50mm x50mm mosiac travertine to the...
6K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
