Discuss Sealing Porceline tiles in the Canada Tile Advice area at TilersForums.com.
anthonyric2010
Hi Guys
Im looking for the correct type of sealant for sealing a matt rustic effect exterion PORCELINE tile I was reccomended a make called Fila.
Although It said it was for this type of tiles and having applied it as of the discructions in this case after a couple of days it all started to flake. This product was reccomended by a large building company In spain.
Anyone know reccoment a good product please.
Many thanks Anthony
Sean Kelly
1,068
Ruislip
anthonyric2010 it's flaking because these tiles do not need sealing. All you are doing is painting on sealer and the sealer is just sitting on top of the porcelain tile. If the tile was a polished porcelain tile then it would need sealing. Test this theory by putting a bead of water on the tile. I guarantee you the water will not penetrate the tile. Do not buy any more sealer! Cheers Sean
anthonyric2010
Thanks Sean
Many thanks for this.. The tiles which are down mark very easily as there a matt rustic type so black soled shoes mark the tile instantly any suggestiond apart from removing you shoes...?
Cheers Anthony
Reply to Sealing Porceline tiles in the Canada Tile Advice area at TilersForums.com
So I had to seal some slate the other week which I did with a paint brush. Just wondered if...
10K
Hello From this forum I understand that I need to seal before jointing and understand that I...
5K
Peter Knight
I have some 100mm sq limestone tiles that are being fixed in my bathroom and need to seal them...
7K
Is it feasible to grout crema g Limestone prior to sealing? Not something I would normally do...
Hi guys I am after a bit of advice. I have spent some time reading through posts but it all...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
