Discuss Self Levelling Help - slab split into two? in the British & UK Tiling Forum area at TilersForums.com.
bugs183
You have to get this baby right, and it will cost, or it will cost you more later if the slabs move.
As everyone says the joint needs to be stitched. Angle grind at 90 degrees and insert threaded stitch bars (i think screwfix sell these, fill with Ecorip. Prime both slabs as said above and cut a 500mm wide strip of Ditra of Dural matting and fix this across the gap with flexible floor tile adhesive. You shouldn't need to use an uncoupling mat on the whole floor.
Level etc as above.
There is a chance the two slabs may move and the combo of stitching and the ditra should do the biz. We've done it between concrete slabs and from concrete onto wood floors, and touchwood we've had no agro.
Ajax123
1,213
Lincolnshire
Thanks for the reply.
The angle of the picture doesn't help, there isn't really a chasm, the two joints butt up against each other. There is just a height differential.
I haven't seen anything about a low viscosity resin stich in my research, is it quite common to use this method? I did consida Ditra matting as I have used this before, but at 20m2 it will add significant cost.
Resin stitching is a very common method of repairing unstable or fractured screeds.
Dean A
Thanks for all the advise.
I have taken another close up of the join.
The previous tiled floor was fine for the 3 years we have lived here, it would be sods law that it cracks for me after the laying the new floor!
Reply to Self Levelling Help - slab split into two? in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi all. I don’t really post, I get all my info usually from just searching. I have just...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
