Discuss Self Levelling Multi Line Laser in the Australia Tiling Forum area at TilersForums.com.
I
Italy
dewalt
DCE089D1G
I
Italy
I can not understand.......
but the laser you use it only for walls and level floors fund ?.
because you have these you can not do the squaring of a floor.
when I start tile floor, in two minutes I know if the four sides of the room are 90 ° and thus change the start. or if the corridor is a team with a room where the start, then the sound of the receiver placed on the ground will make miracles .....
with laser I saw above (Part 1) you can only project to a maximum of 1 line in the ground, of course the cost of my bosch gll3 is high, but much recovery time.
I hope you understand what I have written, and I apologize if maybe I'm wrong. but I got cross laser Hilti, Makita, rubi and stabila before we get to that Bosch :)
Hi Antonio - my laser is the multiline version - cross plus another vertical so its fine - similar to your Bosch i think but cheaper ! DW089k not the one you show .
View: https://www.youtube.com/watch?v=Re-E3ynkwQU
I
Italy
Avevo STABILA, makita, ora con bosch
GLL 3-80 P Professional
un mondo completamente nuovo, sia per pavimenti e rivestimenti, Google tradotto
New
I STABILA, makita, now with Bosch
a whole new world, both for floors and walls, Google translated
@highlandtiler.
we fail to understand.
your laser does not rays is 3 to 360 °.
Your laser is ok to lay tiles on walls.
if you need to do the floor can check the squareness of the room?
I do not think :)
Nice piece of kit but the price tag on it 450-500£
Indeed , and it seems to be a rip off of the Bosch GLL 2 / 3 P , which uses conical prisms to give 360 rather than rotary. Also ( and this is why I opted for the Bosch in the first place ) the Dewalt is:
accurate up to +/- 0.3mm/m
The Bosch is accurate up to +/- 0.2mm/m
Just Saying.
Diggy :D:p
I
Italy
Just Saying.
Diggy :D:p
@Diggy .
you you are looking for fur in egg :)
Reply to Self Levelling Multi Line Laser in the Australia Tiling Forum area at TilersForums.com
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Will this work? (top to bottom) tiling (one room), 12mm laminate (other room) 19mm T&G chipboard...
Our ground floor construction is a mesh reinforced structural concrete floor that was poured...
23K
Deleted member 57709
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
