Discuss Self levelling in the Canada Tile Advice area at TilersForums.com.
Chalker
1,058
Tadcaster
ive got an underfloor heating floor to lay. It's nuheat lopro. Basically it's a stuck down egg box type with 10mm pipes flipped in. That I have no problem with.
But I've then to cover it with thier fibre renforced self leveller. Which under normal circumstances would not be a problem. The trouble is this is laid at 25mm thick over a largish floor. There is a full pallet of leveller and I'm unsure how to lay it and mix it fast enough.
Will it be wise to hire a large mixer, or one of us mix and the other one lay.
Look forward to the replies.
Chalker
1,058
Tadcaster
Wow! I've just ten mins ago had a call from my heating engineer. Ive got to go tomorrow and look at exactly the same thing, only he's said that there is 4 tonnes of the leveller!
Will report back tomorrow when i know what I'm dealing with...
Mine is only one pallet full.
Cold get screeders in with a pump, but will cost a minimum hire for the pump, plus their labour.
Mind you. By the time two of us and whatever gear I'm going to have to hire. This might not be that much of a saving to do it myself.
H
hmtiling
Biggest i did was around 85m2 with the depth varying from 2mm to 26mm. There were 3 of us and about 85x 25kg bags. We had 5 dustbins, 3 pieces of 500x500x22mm sterling board with heavy duty castors on and 2 large mixing drills. All water was ready and measured for 4 bag mixes and all bags opened ready to go. It went very well compared to the other half of the building that we hired a fluid transfer pump for and that seized on the first go:eek:
H
hmtiling
widler
1,328
England
Really imp ? I laid 26 on my own on Friday , I started at 10.30, ,laid 16, had my lunch at 11.30 ish for a hour or so, and laid the other ten and was cleaned up by 2 waiting for the customer to come back from his run to lock up :mad:
IMG_6477.JPG IMG_6478.JPG IMG_6479.JPG IMG_6480.JPG IMG_6481.JPG IMG_6482.JPG IMG_6484.JPG IMG_6485.JPG
One Day
160 bags - to get them mixed and poured in 8 hours - that would be one every 3 mins.
Realistically (and bear in mind I'm tiling this in the end so it's got to be perfect coz my tiling is pants)
I reckon it'll be 3 days with a labourer.
It's not one area either - multiple rooms and hallways.
I've done a pallet in 5 hrs myself - one open room though.
Reply to Self levelling in the Canada Tile Advice area at TilersForums.com
Will this work? (top to bottom) tiling (one room), 12mm laminate (other room) 19mm T&G chipboard...
I’m going to be self leveling my concrete floor I’ve removed tiles today but cannot get the...
I am going to be tiling my upstairs bathroom that has a wooden floor. It originally had wooden...
5K
Had a builder in to build a garage, was planning on just painting garage base but was so uneven...
23K
Deleted member 57709
Chalker
Tadcaster
Business Name
Walker plumbing and heating
Self levelling
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
