I
Ian
Thanks gentlemen for you advice.
Sounds like the Hardibacker boards should be used.
One thing I’m a little confused by; The Hardibacker instructions state “Apply a gap filling bed of non-flexible tile adhesive to the subfloor using a 6mm notched trowel.” Does this mean, in my case, that the non-flexible tile adhesive should be applied direct to the P5 chipboard flooring?
If it does, then I don’t understand why you can’t apply flexible adhesive directly to the P5 chipboard flooring and fix the tiles directly to the P5 chipboard flooring?
The hardie boards are screwed down, the tiles won't be. A cement board is a far more stable substrate to tile to, it does not swell or warp if it comes into contact with moisture, chipboard will.
