Things that will do the job..
LTP Power Stripper
Description: LTP Power Stripper is one of the few products on the market capable of breaking down oxidised boiled linseed oil from the surface of terracotta. With powerful amines, ammonia and alkalinity that penetrate and help lift the hardest, heaviest films, it is ideal for intensive cleaning of heavily contaminated vitrified quarry tiles, glazed ceramics and porcelain. Strips most things first time thereby minimising labour costs.
Tips: Pick this product if you have heavily soiled surfaces, old layers of sealer, oxidised boiled linseed oil, residual grout on the surface of limestone....
LTP Genuine Turpentine
Description: LTP Genuine Turpentine is an ideal primer for terracotta. It penetrates and cleans the very smallest pores of the tile, then dries it to a hard lacquer. As a cleaner, this product may be used for breaking down thick or old layers of beeswax. An extremely good solvent, LTP Genuine Turpentine can be used with LTP Boiled Linseed Oil when sealing terracotta.
Tips:
Technical Data Sheet (PDF)
Description: LTP Boiled Linseed Oil is the traditional pre-polish sealer for terracotta. This viscous liquid enhances the natural colour of terracotta and offers good mechanical strength once cured. LTP Boiled Linseed Oil is ideal for impregnating and sealing even the most porous tiles and can be used with LTP Genuine Turpentine when sealing some terracotta.
Tips:
LTP Antique Beeswax
Description: The traditional way of finishing natural stone, terracotta and quarry tiles pre-sealed with LTP Stone Oil Antique, LTP Stone Oil or LTP Boiled Linseed Oil. This brown beeswax polish protects, enhances and provides a hard protective layer, which helps resist staining. LTP Antique Beeswax is very durable and can be buffed to a shine immediately after application. Maintain with LTP Waxwash on floors and LTP Stonewash on walls.
Tips:
or
LTP Clear Beeswax
Description: The traditional way of finishing natural stone, terracotta and quarry tiles pre-sealed with LTP Stone Oil or LTP Boiled Linseed Oil. This clear beeswax polish protects, enhances and provides a hard protective layer, which helps resist staining. LTP Clear Beeswax is very durable and can be buffed to a shine immediately after application. Maintain with LTP Waxwash on floors and LTP Stonewash on walls.
Tips:
or the modern method..
LTP Ironwax Primer
Description: This product should be used on thick and higly porous stone floors and terracotta before finishing with LTP Ironwax Gloss or LTP Ironwax Satin.
Tips:
LTP Ironwax Gloss
Description: This tough ionised acrylic gloss sealer has been specially formulated to minimise maintenance of quarry tiles, terracotta, brick, slate, stone, terrazzo, unpolished marble and cement floors. LTP Ironwax Gloss may be used as a wax protector in conjuction with LTP Antique or Clear Beeswax. Maintain with LTP Floorshine.
Tips: Interior Use Only. On more porous surfaces pre-seal with LTP Ironwax Primer. Do not use in wet areas.
or
LTP Ironwax Satin
Description: A hard wearing ionised acrylic semi-gloss sealer, that provides an easy to apply self shine satin surface seal on quarry tiles, terracotta, brick, slate, stone, terrazzo, unpolished marble and cement floors. LTP Ironwax Satin may be used as a wax protector in conjuction with LTP Antique or Clear Beeswax. Maintain with LTP Floorshine.
