A 17th Century cottage in sleepy Dorset undergoing a kitchen re-vamp where they have knocked through an old wall into a hidden room (had been blocked off for close to a century!). Called in to sort the slate floor. The original Chinese slate floor was fitted around 10 years ago (some of it over lino floor ). Had difficulty sourcing chinese multicolour slate to exactly match the existing, but got it pretty close in the end. Returning next month once builders & sparkys finished to clean off old tiles and re-seal. New screed poured so that was alright but the old floor was bad........really bad! (anti-fracture membrane under tiles due to cracks & joins)
Pics a bit disjointed as uploading from my phone....sorry!
Nothing special Im afraid, but time consuming and bang on all the same
Alright fellas just though I'd share this bathroom it is 600x300 slate from Porcelanosa some lovely colours in them and nice to use they were not as heavy or as hard as normal slate, just the normal quality stuff from Porcelanosa ImageUploadedByTapatalk1352017236.373474.jpgImageUploadedByTapatalk1352017248.889363.jpgImageUploadedByTapatalk1352017266.589128.jpgImageUploadedByTapatalk1352017284.423208.jpgImageUploadedByTapatalk1352017297.206379.jpgImageUploadedByTapatalk1352017325.706079.jpgImageUploadedByTapatalk1352017338.538785.jpgImageUploadedByTapatalk1352017350.373124.jpgImageUploadedByTapatalk1352017363.306703.jpgImageUploadedByTapatalk1352017382.106476.jpgImageUploadedByTapatalk1352017394.139580.jpgImageUploadedByTapatalk1352017409.589755.jpgImageUploadedByTapatalk1352017433.989595.jpgImageUploadedByTapatalk1352017468.505616.jpg
Currently tiling the bar area of an 8 million quid mansion in gleneagles. Anyway, I have lots of work to do in this house but though id share these pics as it was quite unusual problem i had to overcome, the inner cuts to the bar where no problem using templates but to do the outer cuts, i had to make a jig woth wood and some wheels to ensure it workes smooth (will post pic) then i cut with angle grinder then profiled with diamond pad.
you make me glad I use ring saws! curved cuts are easy- new trick I figured out when trying to fit tricky pieces or notch around something- put one or many rows of clear packing tape over shape/area cutting into- draw cut lines needed on it- pull off and stick on piece getting cut- instant cut pattern transfer. (cut with tape on tile)
For job above- you'd run a few rows over the first cut line on 1 or more tiles at a time- trace cut with fine tip sharpie -measure and mark on the tile cutting in- where the cut enters and exist each particular tile- lift tape and line up ends to those marks- shape is instantly and precisely transferred.
maybe you all knew this already...
Nice Tony!
Here's a few pictures of my current project. Very small bathroom. A traditional style install, crackle glaze tiles, will be a nice cast iron radiator going in next week sometime as well.
View attachment 46519View attachment 46520View attachment 46521View attachment 46522
I've just completed this bathroom today after getting the floor done and fitted the cast iron radiator. You can views these on my face book page (link in my signature) or on my website Kitchen and Bathrooms fitted in Peterborough
the most elaborate mural I've made so far
stove splash and walls on sides of range hood stack. 36" x 70"
Fully 3D carved.
Customer supplied the sun, water.
Re: the most elaborate mural I've made so far
Excellent work Janna, I have just been admiring it on the John Bridge's forum.
Tiling Work Showcase Forum
Dave,
Old Mod,
Dave,
Old Mod,
