Shower Floor Revamp
i didn't think that was swearing saying it in that context?
no that's what i think he meant to say
I will order all the bits and pieces and have a cr--
it should of read ..I will order all the bits and pieces and have a crack at it
:lol::lol: funny at the time
were all human we make mistakes the moderators on here run a strict forum (witch is good)
back on topic i think your former is flexing and may need attention if you remove tiles it may damage the waterproofing (if it goes over former) so try to be careful if you do damage it it needs to be fixed you can try the re grout but i don't hold much hope of that working
good luck
hmm, ok. I think it really does need sorting. I guess if I damage the membrane removing the tiles I can replace it.
Cheers
The tuffdec2 trays need sanding to key them ready for sticking the tanking membrane down with flexible adhesive...as these trays are screwed down and need to be tanked.
If you have grout cracking then ye.. it sonds like some deflection and maybe the tray is not supported properly.. these trays can span 450 centred on joists etc no problem if the joists are all flat and level.. but now and again they will flex if not screwed down properly
Cheers,
I think I'm gonna give it a go. Will remove the porcelain tiles ontop of the tray, repair the membrane (if required) then lay the mosaic ontop.
Obviously if i find the tray is busted or not lying correctly I will look at resetting / replacing it.
Ta
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
