Discuss Shower from hell in the British & UK Tiling Forum area at TilersForums.com.
Gazebo
Hi you can raise a shower tray with an upstand kit (easy plumb kit) but these are usually dedicated to each specific tray.
Some are just plastic leg sets that slot in to pre made holes on the underside of the tray, some are pieces of ply wood with legs screwed to the underside of ply, some are made of box section steel and you assemble them yourself(bathstore).
you could just cut yourself a template of the underside of the tray from 18mm wbp and screw adjustable legs (kitchen base unit legs work.)to the ply. if you do this be sure to leave the ply slightly shy of the exposed edge of the tray so your tile can sit flush to the underside of the tray if you are tiling the upstand that is.
gixer
Thanks Gazebo for the info , After reading the fitting instructions for the tray it appears they do a leg set and panel kit but after phoning the supplier they dont have any in stock and would have to order one in for me . This would hold the job back as i wouldnt be able to tile the floor , Or could i tile right in below the tray as i think i have enough tiles .???
Also if i ran with your idea of ply/kitchen unit legs , what would be the best way of sticking the plyto the underside of the tray ???
Thanks once again Gixer
Reply to Shower from hell in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
F
Good evening all. I need to tile the kitchen floor over the bank holiday weekend. We are having...
13K
Futuregrout
F
Hi Thanks to all who provided advice on my bathroom project 3 years ago, tiling both the...
swanman
E
Hi, Upstairs ensuite with T&G floorboards. Entire floor overboarded with WBP ply. Area under...
8K
K
Hi, I've been getting conflicting advice about whether I should put a DPM behind the marine ply...
6K
Kester Ratcliff
K
Shower from hell
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
