tmid
Hi,
I wonder if anybody has come across this problem before and knows the solution. Our plumber has fitted the shower valve for the overhead shower and it is clear that the gap between the chrome cover plate and the bronze spigot at the back does not leave enough space for 12.5mm plasterboard and 7mm tile + bedding. The gap is only about 13mm whereas we need bout 20mm.There is no margin for adjustment, as the fitments that get attached from the front do not get enough grip on the threads if the distance is increased at the back to accommodate the plasterboard and the tile.
Any advice on a solution would be greatly appreciated.
Edit: links added to show the issue
imgur.com/OS9opbu,oFJH0eC#1
