Sigma Manual Tile Cutters
I've got a query on my Sigma that I've been meaning to ask, when fitting the measuring bar and you try to zero it by pushing down on the spring loaded knob into the ident, on mine there is a lot of play and you can tighten down off zero.
Get a square against the fence and have a look to see how parallel it is with the rail. Then drop the scoring wheel and offer the square up to it and see if it stays true at the top and bottom of the cutter.
Just saw that cutter on the link that callatiler posted, Plan Tec
1000 length to be fair. And if larger I could hire or use a grinder. Or just turn job down more than likely
What size do you fit max?
I’m happy to buy larger just in case. I like to buy well and future proof :grinning:
I chose the max coz i just didn`t fancy the pull version as only ever had push cutters. Klick klock probably just as well suited though
Waluigi,
Doozy,
Waluigi,
Doozy,
