Silicon for use in a steam room
Gents,
Any idea what the best Silicon would be to use in a steam room?
I need to Silicon the glass U channel areas as they have finally started to go mouldy after 6 years of use. I wish I could remember what the last brand was as it's held up so well but I just can't remember.
Thanks!
I personally use Dow Corning for white or clear and Mapei or Ottoseal for colours.
Do try our sponsor @ISOMAT UK as I understand they also sell sealants
Thanks for your input.
I was considering using the above sealents but am wondering if I may need something that resists more heat. The above sealants can handle temps of up to 150f so I guess I'm just being overly cautious as some specialist silicones can handle temps double that, but cost five times the price.
I tried a product called Muffycid which worked really well and removed the bulk of the mould, but the original Silicon is looking a bit knackered and seems to have worn a bit over the years. I think I'll defo change it to keep things looking tidy and fresh in there.
Domosil S looks good with a high temperature rating.
https://www.isomat.gr/wp-content/uploads/2015/12/e-domosil-s.pdf
Has anyone had any experience in using this as I wondering if it sets of hardish due to it's high mechanical strength?
Have you ever measured the temperature in your steam room as 150 degrees f seems pretty high
I always use Dow 785 Sanitary Silicon in bathrooms and wet rooms and would go with that again. Alternatively, I'd ring them up and ask if there was a better product more suited to steam rooms.
We are the only stockists in the UK of the Silicon's, some of our adhesives are stocked by Acorn tiles in Hemel, should you want to place an order just all 01483 511 113
Tanking and Wetrooms
4DoorFist,
ISOMAT UK,
4DoorFist,
ISOMAT UK,
