Slate floor advice
MazzaG
My fitter has laid slate tiles in our bathroom. Unfortunately despite cleaning and sealing the tiles, an ugly cloudy grout residue remains on the floor. It also seems the tiles have not been sealed properly as water stains are also evident which I am told should not appear once sealed.
FILA products were used to clean and seal the tiles- I have tried contacting them for advice but had no luck to date.
My q's are as follows:
My understanding is that I need to 'unseal the tiles' so I can properly scrub the grout (grout/cloud does not appear to come off now sealed). What products would you best suggest I use?
What is the best way to scrub at the tiles once unsealed in order not to cause damage to tiles?
Finally, how do I go about sealing the tiles properly once thoroughly cleaned?
Your advice would be much appreciated!
Maria
Hi Maria
I think you have something going on here, clouding and water stains says to me your sealer is blown.
Slate in a wet situation absorbs minimal moisture through its surface because of the way it is composed, layer over layer.
Slate for example should not be coated with slate seal in an outside situation as if its not grouted with a waterproof grout and the edges sealed in adequately the moisture gets in and blows the sealer. Another reason not to use sand & cement when grouting slate.
Your clouding and water marking could possibly be your grouting is to blame as water / moisture will enter slate from the sides.
Just have a check to see if your grout is finishing near level and you have no dips near or around the tiles at fault.
If you want to strip then look to the Lithofin range it will answer all your needs and give you a professional finish..........:thumbsup:
tiler
"Grimex" by LTP will strip it,make sure area's well ventilated 'cos it'll strip the lining off your lungs as well!!
Hi Maria
tiler
Wetdec
With reference to the above post!
Can you clarify "Waterproof Grout"? Or did you mean epoxy grout?
What do you mean by moisture gets in and blows the sealer? Are you talking about a topical sealer or penetrating sealer?
Kev
Maria
Depending on the exact sealer used I would take note of Wetdecs post but any sealer used will need to be stripped. The best product for this is Aqua Mix Sealing & Coating remover as it has very little smell and is a safe product to use. You will need to follow the instructions carefully:thumbsup:
Kev
Kev
That is your opinion only though.....there are many other products equally as good or even better for certain applications...:thumbsup:..
Absolutely Dave!!! Couldn't agree more!!! All my posts are In My Opinion only and I am happy to use another stripping product out there on the market if its more user and customer friendly:thumbsup:
Kev
Wetdec
Kev
Because of the nature of slate and the way its cleaved the only real way in is through the cut edges. Slate specific sealers are topical to my knowledge as they enhance and therefore can be seen to blow, they co cloudy / white as the moisture gets under them. This is confirmed by lithofin not promoting slate seal for outside use some years back.
Waterproof grout as such doesnt exist unless epoxy but using a standard grout will prevent water ingress and so reduce moisture absorbance by the slate through its cut edges and getting under the sealer.
tiler
Slate floor advice
MazzaG,
wetdec,
MazzaG,
wetdec,
