David Rowell
Ignore the comments about ripping customers off - everyone has a first job in a different type of tile, knowing slate is not your usual type of tile you've been wise to seek advice before hand, that's sensible! My first slate Job was 95sqm of uncalibrated slate and I used a 4" grinder for it all, I was advised by a guy who only works with stone to not use a wet cutter unless plan on leaving all the cuts to dry out as shouldn't lay them wet, it was dusty as hell but turned out well haha! Remember to work clean whipe any mess off as soon as any touches the slate as it will stain and I'm sure you know to seal it before grout etc?
Cheers stocks top man:hurray: Ive got flexible adhesive, primer, grout and yeah i got a sealer for slate Ill take my time and wipe as i go. So come to grouting what would you suggest method wise if the tile stains? Or will it be sound if i keep it clean?
