Discuss SLC onto plywood in the British & UK Tiling Forum area at TilersForums.com.
stan1888
Hi is the above possible in the following situation:
Want to remove old tiles that were put down on 15mm plywood which i believe were screwed down every 6 to 8 inches onto floorboards. Don't think the customer wants the ply lifted incase it wrecks the floor underneath. So would it be possible to just lift the tiles, put down a slc and re-tile? If so what slc to use, BAL Multibase/ Acrybase?
I've used slc's on concrete floors but to be honest was not sure if they can be used on ply when tiling (thought this was for soft floor coverings only).
Thanks..
Reply to SLC onto plywood in the British & UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, DIY home owner here in need of advice. Following a waste pipe leak that's now been fixed...
Hi all, Quick question, when installing 6mm backer board onto a floor prior to tiling, would...
SLC onto plywood
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
