Discuss Small floor large tile layout question in the America Tile Forum / Advice Board area at TilersForums.com.
Hi guys, im doing a small downstairs cloakroom with 600 x 600 terrazzo tiles. I cant decide on the layout. The width is just under 1.1m so i can either go 1 grout line up the middle with small cuts on 1 side of each tile or 1 full tile up the middle with a cut tile on each side. Has anyone done a small.area like that with a large tile that could advise what looks best. I'm not a tiler so I dont have much experience.
I have attached a sketch for reference
I have provided 4 different symmetrical options bases on your drawing (estimating dimensions of walls). If you go for non-symmetrical then the options are limitless. It is important to position a full-ish tile at the doorway/entrance....
I know this is a very simple room layout but if you was interested you could investigate (for FREE) the different layout options in a few seconds using ProtoTILER.
Thanks for the detailed response!
The room is approx 1.1 in width and 1.53 in length. I suppose the layout I went with was going to determine my method of cut. If it was your image 2 I would scribe and grind the slim cut. If I went with image 3 I would use the sigma .
I still get really nervous slim cutting 600's so I tend to play it safe and grind. Because they are terrazzo I would prefer a more seamless look I think but like to hear a professional opinion.
Reply to Small floor large tile layout question in the America Tile Forum / Advice Board area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
USA Tile Forum Popular
America Tile Advice Trending
Belfast
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
Business Name
chrisc123
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
