Discuss Small wetsaw for mitres. in the Canada Tile Advice area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Need some suggestions please guys. Im doing some metros in the kitchen im on at the moment. Im using my Rubi DU200 bridge saw to do The mitres and having a bit of a mare! I've got a very good blade in it But im finding the motor is perhaps not consistent enough and the water pump is pretty pants. Im getting ok cuts to continue but not perfect so im not happy.
Anyone got any suggestions of an alternative saw? Want something small to do mitres up to 300mm tile size. Im going to invest in a much bigger say in the future. But for jobs like this it would be over kill to pull out such a beast for such small format.
I refuse to use trim, especially on metros unless the customer demands it. But i need something that will leave a nicer cut.
AliGage
Subscribed
4,531
1,188
I have a couple of little table saws but as you say they're pants.
Cam what size tile will the 9p cut? I say your post the other day and if something to save toward. But i wanted something smaller and lightweight. Therefore cheaper for such jobs as kitchen splashbacks where you've only got two window reveals and approximately 8 mitred joints to do.
But if the 9p is as good as you say it is and light and easy it could work. Just not affordable right now.
White Room
It cuts 42cm in length and 30x30 on the diagonal. However with the guide off it will cut as long as you wish to follow a pencil line.
I wish I had bought one years ago. I cannot stress the mitre function and its perfection along with the guides accuracy.
I may do a review tonight!
With the guide off are you limited for doing mitres....
AliGage
Subscribed
4,531
1,188
The Rubi i bought because i had 50 plus metres of travertine to cut in half do a job. So it suited purpose for that. Plus at around 100 notes inclusive it was a steal.
The problem it has though is when you turn it on its 45 the motor makes the whole bridging rail wobble. So what i found today was that the glaze was chiping slightly on the edge of the cut. Wasn't major but enough to pee me off. Wasted a few tiles in the process but most i could lightly file to sort out. But it's a pain. Need something better. But i like the idea of having a little machine dedicated for small format mitres i can leave setup alongside my other cutters and saws.
Reply to Small wetsaw for mitres. in the Canada Tile Advice area at TilersForums.com
Hi all, first post on this forum. I am a plumber based in North Yorkshire, when tiling bathrooms...
Was just getting my tools out of the garage ready for tiling to start this weekend and I'm...
2 3
7K
hallo, in my winter holidays i thinked a lot about tony. :-) i do mitres in most of my jobs...
2 3 4
24K
rainsco
How do you guys/gals get thw best results when mitering. I dont seem to be getting a good clean...
Sean SML Tiling
Hi all hopefully I am going to post a completely unbiased review on the sigma 10m9 wet saw...
20K
AliGage
Subscribed
Website
http://www.Facebook.com/AllisterGage.Tiling
What member type are you?
  1. Professional Wall and Floor Tiler
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
