Flooring Grade Class 3 ply-wood or Hansons SP 101 ply-wood fixed at 150mm centers, Tilemaster Primeplus, Tilemaster S1 adhesive. Done and guaranteed.
Which thickness ply do you use for testing. I have only ever seen SP101 in 6 and 9mm.
I have to agree with you as I have also seen the failure at floor joint that has had hardie used on it .and how does an adhesive that can stick a tile to the correct wood flooring type handle the joints in said correct floor?
this is where most failures happen imho
