MICK the Tiler
When you lay tiles on the diamond you ping down a line in your set-out to give yourself a point to point start so that you are sure you are at 45 deg. Then you simply work in rows like you would if you are laying square.All you have done is turned your body even though the tiles are angled you still work the same.
