Discuss step door trims?? in the British & UK Tiling Forum area at TilersForums.com.
kilty55
1,113
edinburgh
evening,i need advice on where to buy a trim for a small lipped step up from a vestibule tiled floorup about 4 inches to meet another tiled level floor,,hope that explains it?? it needs to be chrome do ctd sell these or schulter systems would that be a good bet? not used any of these yet so need a wee bit advice guys cheers:thumbsup::thumbsup::thumbsup:
DHTiling
This is a good one...again availabe to order from CTD...
Schlüter®-TREP-E
Schlüter-TREP-E is a stainless steel stair nosing profile with a special non slip tread to create safe and attractive stair edges. The profile can be integrated into stairs covered with tile or natural stone, as well as into a screed or surface coating that is a minimum 2 mm thick. The profile is especially suited for applications in building areas with heavy foot traffic, such as commercial areas or public buildings.
Schlüter-TREP-EK is a profile without anchoring legs for adhering to the edges of stair nosings. The profile is well suited for subsequent installation over damaged edges, eliminating the need to replace the entire step.
Schlüter-TREP-E protects the front edge of steps and adds a high degree of safety due to the tread’s high visibility (Certified by the German Institute for Occupational Safety and Health (BGIA), classified as slip resistance category R10 V4) and special slip resistant design.
DHTiling
Or this one.......
Schlüter®-TREP-T/-MT/-TL
Schlüter-TREP-T/-MT/-TL is a special profile made of rigid PVC with a soft, non-slip PVC wear surface for a safe and visually appealing stair nosing design.
Schlüter-TREP-T has a consistent, uniform colour at the wear surface (four colours are available), while Schlüter-TREP-MT features a decorative brass inlay.
The profile Schlüter-TREP-TL features a luminescent inlay, which glows for up to 10 hours after exposure to light. This increases the visibility of stair edges in the dark and at dusk.
Schlüter-TREP-T/-MT/-TL are intended for residential use or light commercial areas. The profiles are permanently installed in the covering and cannot be replaced when damaged by excessive wear (Schlüter-TREP-S and -B offer replaceable inserts).
Schlüter-TREP-T/-MT/-TL protects stair edges and reduces the risk of accidents through its non-slip tread design and increased visual acuity. Matching end caps are available.
DHTiling
and also this one.......
Schlüter®-TREP-FL
Schlüter-TREP-FL is an aluminium stair nosing profile with a protruding rounded edge and a special non-slip tread to create safe and attractive stair edges. The profile can be integrated into stairs covered with tile or natural stone.
Schlüter-TREP-FL is particularly suited for areas subjected to light foot traffic, such as private homes or similar interior applications. The profiles are permanently anchored in the stair covering and cannot be replaced when they are worn out (our products Schlüter-TREP-S and TREP-B offer replaceable thermoplastic treads if these are required).
Schlüter-TREP-FL protects the front edge of stairs and adds a high degree of safety due to the special slip resistant design of the tread and the high visibility of the stair edges.
DHTiling
Or this one provides a nice flat finish but no slip protection and comes in chrome and stainless steel......
Schlüter®-SCHIENE
Schlüter-SCHIENE is an extruded profile that finishes and protects the edges of tiled coverings, as well as other surfacing materials.
Applications include: transitions between different surface coverings (e.g. tile to carpet); dado coverings; edge protection at expansion joints; decorative edging for stairs; as well as a finishing profile for all types of surfaces, such as carpet, parquetry, laminates, natural stone coverings, or cold cured resin coverings.
The profile’s unique design combines specific angle positions and material wall thicknesses to transmit point loads into the substrate and surface covering, thus protecting the covering’s edges against damage. The joint spacer, which is integrated in profiles higher than 6 mm, establishes a defined joint cavity between the tile and the profile. The anchoring leg of Schlüter-SCHIENE, in all material types, can be punched with a special radius perforation “R” so that the can be used to form curves.
Reply to step door trims?? in the British & UK Tiling Forum area at TilersForums.com
Supplied and fitted a en suite shower room, finished it a fortnight ago but the customer still...
18K
11K
Rizzle from the Portizzle
Hi all, (I have tried looking but could not find this subject covered in another thread, if I...
14K
JamesHardie
Hi All, Having our bathroom tiled and fitted, we are 4 days in so far and its not looking...
2 3 4 5 6
9K
Qwerty
Q
Bit of a long read......but it made me chuckle a lot. Pocket Taser Stun Gun, a great gift...
Dougs Third Go
kilty55
edinburgh
step door trims??
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
