how bigs the cut at the other end ?, can you not budge it up a bit to half a tile cut in the door..
if you put a full tile in the door way then the whole floor will have to be squared off the doorway, or you may end up with a full tile one side of the door and 10mm gap the other side, or 10mm slither off a tile, I would budge it up and have half a tile each end..
Ah yes obviously the door won't run straight so you're right - over sight on my part.
So if I measure off my centre line enough to give half at the door and snap a new line here I'll be ok correct?
yep, if you can work it half tile each end then fine, its allways best to cut into doorways, walls etc, incase they run out....
If the tiles aren't square to the door, it will look hideous! Hard to advise as we can't see the full room layout, but a crap cut somewhere less focal might be better.
basically ive squared the design on the room centre so the door is running off very slightly at an angle.
How do I re-square on the French doors?
what wall are you squaring the room off..? is it one of the walls to the side of the French doors..?
