Discuss Stone Floor Lifting in the UK Tiling Forum area at TilersForums.com.
Michael Coughlan
Hi all, I would really appreciate any opinions on the following scenario. Thanks in advance for any help.
House was 20 years old. It had a large hall with carpet on floor (50M2). Carpet was removed and concrete slab was exposed. It was dust free and dry but and reasonably level. Devi underfloor heating cable was installed and a 2 part latex screed poured over it. 2 days later large format marble tiles were installed using ardex flex 5000 white. Tiles were buttered, and fully bedded. 2 and 1/2 years on and several of the tiles are lifting. Hollow sound etc under them. I removed one today very easily using suction cups (after removing any remaining grout). Tile decoupled from adhesive bed easily. Adhesive bed was full ( no voids). The middle of the bed was swollen up in a slight curve which would explain why the tile was rocking on it. I used a kango hammer and removed the adhesive. It was rock hard. 90% of it was still bonded to the levelling compound. However when the compound was removed there was drips of water on the underside and the concrete floor itself was wet.
Michael Coughlan
It's an older self filling system from a little tank in the attic so not so easy to guage water loss. i could tie up the ball **** I suppose and observe it for a bit. I thought of a heating leak before but there are several tiles lifting in different locations. Even ones in the utility room very far away from the particularly bad ones in the hall.
Michael Coughlan
I don't know whether there is a dpm installed (I assume there is) and if there is whether it is fully in tact etc. I have studied the areas of the house that are not tiled and there is no obvious dampness apparent. Would a very low level of dampness only become an issue when it's trapped in with the latex and waterproof adhesive?
Michael Coughlan
Get someone in to measure moisture content in the concrete slab to confirm the rising damp theory? Are there other things that could be assessed? Should the entire floor have been "tanked" like they did in all of the bathrooms and "seal the dampness down"? Entire ground floor of the house has over 200 meters of marble
Reply to Stone Floor Lifting in the UK Tiling Forum area at TilersForums.com
Stone Floor Lifting
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
