Guest viewing is limited
Discuss Stone Floor Lifting in the UK Tiling Forum area at TilersForums.com.
marble tiles were installed using ardex flex 5000 white. Tiles were buttered, and fully bedded. 2 and 1/2 years on and several of the tiles are lifting. Hollow sound etc under them. I removed one today very easily using suction cups (after removing any remaining grout). Tile decoupled from adhesive bed easily. Adhesive bed was full ( no voids).
might be a couple of problems including Hydrostatic pressure or rising damp affected the slc. Did the slc come away reasonably clean from the concrete?
the other question should be asked is why did the marble come away easily from the adhesive? The adhesive used here is ideal for damp areas so no problem there but has the moisture finally affected the marble itself. Now that you have this moisture has it and will it continue to affect the marble/adhesive bond? Some marbles do not like moisture at all and thats why the need for special adhesives for marble of which ardex flex 5000 is not.
Like Dave said you need to find out where the moisture is coming from. This can be achieved with the right equipment and expertise.
I would remove a few more of the affected tiles check for moisture and take some photos. Clean and dry the exposed concrete then get a professional in with the correct moisture meter to check the slab for moisture. They might even take up an unaffected tile to check for any pattern in the moisture affected area or perhaps even use thermal imaging equipment to check the extent of the moisture affected slab.
one other question, is there any white powdery substance in the joints and are there any unusual stains appearing through the marble? thats two sorry.
I hate to be the bearer of bad news but when you solve the problem of where the moisture is coming from , it will take some time for the whole slab to dry out if it ever does. If the slc has blown now it may continue to for sometime. This is not just some bathroom floor that you could rip up and fix the problem, so i would strongly advise you to hire an expert in problems like this and can provide you with a comprehensive service. You dont want to go through and have to pay several "experts" when you only need one.
Perhaps one of the guys on TF has some experience with these issues or can recommend someone.
I live just a wee bit too far away to have a look for you as i've done a lot of insurance assessments and find these issues very interesting.
In the meantime as well as the others i'm sure, i will give your problem some more thought.:detective:
Michael Coughlan
Did the slc come away reasonably clean from the concrete? In general Yes but not totally. Bond between the adhesive and slc was fully intact though.
s it stone tiles or slabs,some marble has fibre glass resin on the back this can sometimes cause problem such as you describe . 60 by 60 by 20mm tiles and yes most of them had a plastic type backing with a square mesh design. I thought these are standard on marbles that are prone to breakage.
is there any white powdery substance in the joints and are there any unusual stains appearing through the marble? No, none
(btw, a name would be helpful) Sorry, Michael Coughlan. I just set up my account here recently in a quick mode to view posts. Now that I have posted myself a name would indeed be suitable. To that end I have contacted the admin of the site and they are going to change my user ID.
It appears that reinforced resin on the back of marble or any stone and tile requires an appropriate adhesive to ensure a good bond to the substrate.
Their does not appear to be any standards for the application of the resin backing so it is the responsibility of the installer to ensure that the correct adhesive is used.
The marble should have been fixed with an adhesive that is not only compatible with the substrate but also with the resin reinforced backing to the back of the marble tiles.
The adhesive required will depend upon what type of material has been attached to the back of the tile.
here is a link for a report on the subject of resin backed marble and stone http://www.laticrete.com/portals/0/tds/tds150.pdf
The problem you face now is twofold. A moisture problem that has reacted with the slc which has caused a dominoe affect by creating a secondary problem with the possible inadequatly adherred marble tiles:yikes:.
Once you solve the moisture problem, hopefully the secondary problem will resolve itself seeing that the marble has already been down for two and half years.
Has anyone seen this or heard of problems with the resin reinforcement on marble tiles? Apparently the backing is normally used on thin natural stone and marble. Also i know that the extra large format tiles between 3 - 5mm thick have this backing.
Is going to be a problem?
And will the industry require the more expensive adhesives be used to ensure adequate adhesion of the tiles?
What do you know and what are your thoughts on this guys?:8:
Spud
the resin backing should have been removed from the stone prior to laying them, there have been a few posts on this subject, the resin is used to strengthen the tiles for transit purposes only not many cement based adhesives stick to it and it seperates from the adhesive bed after a while call the stone federation and they will give you very good free advice on the subject 01303 856123
Reply to Stone Floor Lifting in the UK Tiling Forum area at TilersForums.com
Stone Floor Lifting
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
