stone sweating and staining under cordec.
jonnyc
I have just had a call from a stone company who have employed my company to fix a limestone floor.
the stone was predried in adryong room and presealed with stainstop mn.
dd
sir ramic
yes ?????
i am fed up with trying to write a post and getting timed out and losing the content.
i am really at a point when i dont want to post what i think are good questions any more and just give up.
i have just spent 15 mins writing about the problem i have only to loose most of it when i try to post.
sean
thanks for that advice .
maybe that works i dont know because havent tried.,
all i know is that i see something that says auto saved but it does not save everything i write and then post.
maybe i am just useless at this sort of thing but i do seem to manage on my internet banking and other related business.
i have to say that i am losing interest in posting what i perceive to be interesting topics that take more than a few sentences to put out.
Try ticking the 'remember me' box when you sign in, i was having trouble too a while ago.
I'm guessing you've laid a floor, put corex straight over it and when removed you can see a difference.
It's great stuff and i use it alot, but i thought the floor may sweat so i try and leave it a few days.
Well it is going to sweat as the cordec will not let water/moisture through, and neither will the stone if it has been sealed ,and the adhesive would have contained a lot of water when mixed which has effectively been trapped !!!:thumbsup:
I use Tapatalk so can't talk out the timing out thing but once you've typed it all, right click, select all & copy, then hit post or reply. If you get timed out, just sign back in, right click again & hit paste. Saves you jumping between word & the forum
thanks for trying to help me guys . i saw two moderators watching this thread but they did not contact me to try and help so i am out.
i agree jonny it is frustrating and has been mentioned many times it really does need looking at by the admin
I use to have this problem and ticking the 'remember me' box when you log in does sort it mate. I too was confused for quite a while but no problems anymore
by the way if it does log you out sometimes clicking on the 'back' button in your browser can recover it, somethimes not ;(
I keep getting logged out thru google and have to reload, pain in the butt but no idea whats happening.
i cant even see the forum topics on the first page anymore, and i have to keep clicking whats new to follow what we are all talking about,and that is annoying me!!!!!
Well excuse me while I extract the magic wand from my backside.
Maybe if members would report these issues directly to admin or mods then we could look into it. But...think of it this way, if it were a common fault and one directly linked to this forum then why is it not happening to everyone. It certainly doesnt happen to me and never has ....but then I dont think I have ever spent 15 minutes writing one thread.
That said it could be just that , that the software sees it as inactivity.....but then again I leave the forum on when ever I am in the house even if I am not reading it and dont have this issue. If I cant replicate the issue then I cant see what you see and neither can the mods.
Other issues may be causing this problem like your Internet provider or maybe the way your PC is set up... My honest answer is I dont know , So I need to pass this over to Dan.
Throwing a tantrum wont solve it though.
sorry got a bit annoyed as i have a problem to solve today and hoped someone could help with answer.
i will be brief.
stone presealed with stainstop.
fixed grouted and sealed again and finished last week.
i was asked to put building paper down and then cordec by stone company but i said cordec was not a good idea as i have had experience when the floor has sweated under cordec when heating left on for months whilst building works were finishing.
whole floor had to ground down and repolished.
i was not blamed as i only put building paper down and contractor put down cordec.
so i only cover with paper this time as before.
builder has now had other trdes in with muddy boots and ripped up paper and client complaining .
will write last bit when posted this in case loose it.
i now have to go down tody to patch up floor with more paper.
one question was why cant put cordec down if stone presealed and therefore floor dry now.
i think the answer is that floor can sweat even if stone dry because of ait trapped between stone and plastic.
is this correct and would this only happen if heating on or even if not on?
other question is does anyone know of another product that could be used instead of cordec on top of building paper. it must be able to breath.
dont want to suggest ply or hardboard as have had problems with that as well if something gets spilt on it and resin can bleed in to stone.
i will be on site in 2hours and any suggestions i can give contractor would be good.
they are not used to doing stone floors i think and think i am being over fussy.
Cookie Problem / Being Forced to Logout
Apologies for not picking up on this sooner. The problem is nearly always related to your locally stored cookie in your web browser. I've just changed the cookie prefix so everybody will have to login again, and that'll store a new cookie, and should solve the problem.
Here is how to fix it your end in the future though:-
Login to the forum, then click log out. You'll get a message saying your cookie related to the forum has been erased. Then close the web browser down fully, start it up again, login to the forum (remembering to check the box "remember me") and that'll store a fresh cookie with no issues related to it.
If that doesn't work your web browser isn't letting the forum erase your cookie. So you can manually erase it. I'd need to know what browser you use to help you do that though.
You can also use the auto-restore feature if you lose anything you've typed on the forum for whatever reason. If you logged back in, went to start a new thread again, and look in the bottom right hand corner of the message area you should see the wording 'restore post' which will restore your post. You've probably seen the yellow box pop up when typing a long post about every 20 seconds saying "auto saved". So it'll pull up the last saved point. You might end up with a couple of sentences missing on the end.
Though as I've said before over the years, it's not a forum problem, it's browser and operating system related in 99.9% of all cases.
Make sure you keep your browsers up to date. And to test if it is your browser, try using another one just for 10 minutes and see if that kicks you out, I bet it doesn't (unless it's using the same cookies).
Jonnyc I am having the exact same problem at the moment so would be very interested in a solution.
Ive laid around 120mtrs of Basalt(!) and some areas under the cordec have sweated leaving white deposits. other areas are free from staining so it's not the end of the world. Had a bit of a mare all round with the basalt, but that's a different thread...
Ok I know basalt. I will try and find your thread about your problem and see if I can help.
one thing I can say al is that even though have been fixing limestone for 20 odd years I am never surprised by the problems stone can throw at us.
every stone has it's own little individual features and some of these are destined to try us.
strangely I like this as it is so much more interesting than just laying a ceramic as was the case 25years plus ago . I would have been bored stiff and given up tiling within a few years.
but early 80s the terracotta and slate came in and I loved the variance and challenge.
I don't know how much stone in general you fix but basalt i have only come across and fixed in last 7 years.
theres all sorts of new stuff coming in with their own set of problems and it's all fascinating stuff.
this is where I have found the forum so helpful.
there are guys on here that specialise in porcelain and I have been given some invaluable advice.
my little boy has just seen the icons on rights of screen that I have never even looked at before and he chosen to give this a :thumbsup:
hope can help
Al just had a look see about your business and it appears that we have connections.
i know graham Oliver from many years ago when he worked for castellnau tiles iin Barnes before he went off to do his own thing with Hyperion.
think he's done really well on his own and we have probably quoted against each the other.
another connection is doug Watson. He was the man that supplied Paris ceramics with their Spanish hand made crackle and all the
Paris ceramics feature panels
Would love to talk .
theres another connection between you and me that escapes me at this moment.
Never mind .ive had a very stressful day and let's talk in next few days.
What I will state that we would never have met up if it was not for this site.
we all get lost in the microcosmic world as we live in and this site brings us together .
^ I like your new posting style [MENTION=15118]jonnyc[/MENTION] - lots of smaller posts to make sure they get posted 😉 😉 ^
Hello again jonny. Nice to hear we have connections! Going back a few years to my tile making days with Doug but I do still see him around.
This site has been a great source of info to me through the years and is invaluable to anyone serious about their profession.
I hope tomorrow is a better day for you! Me, I will be scrubbing a floor....
jonnyc,
Al@Lifetiles,
jonnyc,
Al@Lifetiles,
