Discuss Tanking law.. in the UK Tiling Forum area at TilersForums.com.
DHTiling
Who thinks that we should have a regulation introduced that bathrooms etc...should have the same regulations as most other countries have....and that we should be licenced to do so....?
By this i mean tanking/waterproofing...this would be a failsafe installation for the customer and only licenced installers can do it...but also all bathrooms must comply to this regulation....
After all a water tight room will then not be bothered by any water ingression be it on the walls or floors...:thumbsup:
cornish_crofter
In principle I would agree, but we run the risk of over complicating the building regs to the extent where people just don't follow them anymore.
This is already happening with Part P of the building regs (Domestic Electrical Installations) I have 16th edition and C and G 2391 (inspection and test) and I regularly see professional builders and kitchen and bathroom fitters bending the rules with this one.
On the other hand the 17th edition regs themselve (not Part P but BS7671) are not actually mandatory. Part P that dictates that certain work is within scope and has to be certified is.
BS7671, although not mandatory is recognised as a defence to accusations of poor workmanship etc. In other words, if an electrician cannot claim that he worked IAW BS7671 then he has to come up with another defence to defend himself against such a claim.
I would welcome such a document to cover bathrooms along the lines of the way that BS7671 splits a bathroom up into zones.
There is a diagram on this page that explains how the zones are defined:
broken link removed
Go to Page 8
Zone 0 is inside the bath or shower cubicle
Zone 1 is directly above the bath or shower up to a height of 2.25m
Zone 2 is within 600mm of the bath or shower and up to a height of 2.25m
Zone 3 is within 2400 of zone 2 up to a height of 2.25m
This is an older document but I don't think these have changed with the 17th edition.
Perhaps a recommendation or a BS that we can work to would be a good move. This way we can recommend this to customers, but we won't be procluded from doing the work if the customer is not prepared to pay for it.
The other issue is that electrical installations have to be tested. In other words the tester has to submit certificates indicating continuity, impedence, resistance and earth loop resistance values obtained during electrical testing. How would you put a test value on tanking to indicate that it had been done in accordance with the regs?
cornish_crofter
I think you would need to specify permitted tanking methods within say 700mm of a shower rail in one direction or the width of the bath, or within total enclosed space of a shower panel etc
These requirements could include tiles up to say min 1800mm above base of bath/shower tray on say a class A tanking arrangement, which would be defined separately. I would suggest Class A would include a choice of BAL tanking kit applied as per manufacturer recommendations, hardibacker, tilux membrane etc etc.
Then you could downgrade the requirement for areas outside the defined shower area.
It would need a lot of thought, but before you could pass a law or even set a standard, as Whitebeam says, you would need to pigeon hole the tanking solutions we've got out there.
This is the problem that we have at the moment. You walk into topps tiles and are told that the BAL Greenstar is fine for domestic showers, but with the no nonsense shower panels I fitted the other week, I would not have wanted to use it!
Reply to Tanking law.. in the UK Tiling Forum area at TilersForums.com
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Tanking law..
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
