Discuss Tanking law.. in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Which countries are those Dave? Maybe we could look for some guidance on the web published for those countries.
ones i know of are...
1 : usa....some states( need to check which ones )
2 : australia.....as mentioned by mick
3. Sweden ...as mentioned by sWe....
if anybody knows of more feel free to add them..
oldgit
personally i dont think it should have anything to with tilers on new builds,if regs require tanking or boarding with a water proofed product then fine but if i was a tiling contractor there is no way i would be guaranteeing water tight areas.,imagine the lawsuits cropping after a tray has dropped 10mm and the tilers get the blame.
in a domestic situation for me its down to the customer,but maybe insurance companies should refuse or reduce premiums if a shower is tanked or not tanked.
i think tanking is only part of the answer to the said problem.
to me its not the walls that are the issue its the sealing of wall and floors joints.
water imo does not attack wall or floor substrates unless it can get in from a joint and by joint i exclude the tile joint as this is miniscule.
by water proofing or tanking walls and floors you will only push the problem somewhere else.
DHTiling
I just think that something needs to change.....how far this change goes then that will need a lot of work.....we are seeing to many failures of installations in bathrooms etc and peeps claiming on house policies for damaged ceilings/walls due to minor water leaks/penetration...from up-stairs.....
keep the suggestions coming please...they are great...:thumbsup:
cornish_crofter
The main problem is, as Wetdec said on the phone to me when I spoke to him about wetrooms, is that we have been demanding more flow rate from our showers.
20 years ago we would be lucky to get 2 litres a minute out of a shower. A few weeks ago I fitted 2 shower panels, each of which deliver 6 litres a minute, and that is relitively low these days.
So we're now getting up to 4 times the volume of water chucked at us when we're in the shower, no wonder things are getting desparate.
oldgit
the problem what is now called tanking in a shower or bath area probably wouldnt prevent this,new builds for a start move or shrink far too much,also floors upstairs are tiled far too early in new builds imo,without the correct precautions but this should not be a tiler responsibility.
DHTiling
Then what solution do you think we could have to this..?
Maybe a set time allowing for shrinkage should be enforced in new builds....
anybody else got any ideas on this theory..?..
Reply to Tanking law.. in the British & UK Tiling Forum area at TilersForums.com
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
Tanking law..
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
