tanking - why?!
hi northern bird
where can i get all the info i need on backerboards ie sizes, types, how to install, tech spec etc
ross
in response, as a professional tiler specialising in domestic work, i want to guarantee my customers that their shower enclosure wont leak, not that if or when it does there is damage limitation in place!
this is the point i have been driving at and no-one so far has convinced me otherwise!
if epoxy grout stops this, why not just use it?
also hardibacker boards are waterproof anyway.
ps i dont want to "sell" tanking i want to do the best tiling job possible.
i am happy to put the stuff on, god knows its not rocket science, i am just uncomfortable with the thought of water behind my tiles!
best regards, adam
If you use cement based adhesives then it will with stand as much water as you can throw at it .. so to speak...after all swimming pools are tiled in it and are immersed in water for very long times.......if the correct adhesives are used then water will not affect them..it's the substrate that needs protecting from constant wetting.......not the adhesives or grouts........if correct ones are used.....
what i would like to add about tanking is that its a very easy process that seems to confuse a lot of people and some of the prices that some people charge dont reflect the cost/labour ratio. i have heard of some people charging upto 250-300 to tank a shower area and that is blatantly ripping the customer off in my opinion. everything has its price!
ross,
try..... www.backerboard.co.uk and www.aquapanel.co.uk
hope this helps
ed
I usually charge for the tanking kit and fit it for free. As Ed said - it's easy to install and one tanking kit will do about 3 or 4 bathrooms.
Waterproofing is mandatory over here, but since customers generally want to get away as cheap as possible with materials, I charge labour in relation to application time and drying time.
New regs say waterproof membrane or waterproof substrate with sealed joints for domestic bathrooms, but until the 1st of July, you can get away with using the older, cheaper, roll on systems. [Sidenote: over here, the whole bathroom is tanked, not just around the shower and bath tub]
I discourage that by charging more labour for those, as most of them take almost a day to dry (especially the cheap ones), and I still need to get paid for the entire day you know.
The membrane systems are faster to apply, and dry alot faster.
Thus, I can usually begin to tile the same day I apply them, saving me time and allowing me to do more work in shorter time. There is little or no cost increase for the customer, even though the materials are much more expensive (about 30%). The end product is also better and more durable, which is good for business.
I use the same approach when leveling. I don't use cheap crap which dries 1-2mm per day; I use high quality gear which is tileable the same day, or the day after if it's in a bathroom. This approach allows me to focus on one job at a time, and that saves me stress, and gains me more money, as I have more chargeable time than I would otherwise.
those web sites are excellent, just found www.wedi.co.uk and theres loads of info on you tube if you type in wedi....got all the info about fixing today from that but it mainly echoed whats been said on here, really interesting stuff
thanks,ross
Tanking is an essential part of a bathroom installation whether its for a shower, general bathroom or wetroom. Todays buildings being made like boxes that will turn to mush if you add water have seen to the importance of tanking.
In Europe its law and its on its way over here, if your honest who in his right mind would have accidental spillage of water over an electrical socket no one yet people happily put showers, wetrooms, free standing baths over kitchens etc. with no waterproof membrane.
If your doing a bathroom then tank the floor it litteraly takes an hour to do a good job and you know its safe, walls around. A bath shower can be done but go to the floor costs a few pennies more and its a solid job. Showers/wetrooms need the walls tanking 200/500mm outside the shower area and the floor below so say 5m2.
There are a few waterproof membranes to be had which are made for the job.
Membranes vary :
Tilebacker boards are ok but are generally more expensive than a really good membrane. Tilebacker (Wedi) 5m2 £140 + tapes
Paint on membrane (mapeigum) is there to be used but due to thickness variations when applying working conditions and differing ideas on how it should be used its not the most consistant of products. 5m2 coverage £35/45 + tapes
Tanking mat durabase is a system on a roll which is stuck to the walls with flexible adhesive so no paint brushes and seperate tubs required. Put it on like wall paper and it is an actual barrier between tiles and substrate. 5m2 £55
Tilesafe, the market leader pays for all its advertising by charging £175 for a 5m2 kit but like all others it has its place.
As a solution that is consistant and proven then Durabase or Kerdi ( no drying time, waterproof absolute) are the solutions the pro's should be using as they are the the undoubted way that this sector is going to go........ a sheet membrane system.
Not being unfair to any we sell them all at www.wetdecs.co.uk, if they arnt on the site then a simple email or call will get it sorted.
Hope this helps out a little
tiler
Let me put it like this:
In Sweden, it's been law to waterproof entire bathrooms and such, since the eighties. The standards have developed, and the rules have become more and more stringent. For about 13 years, roll on kits and joint tapes have been standard, but it's not enough it seems, because the insurance co's still pay up to the equivialent of £10m every week for water damaged properties, and that's in a country of about 9m people. Granted, the water damage claims are nothing now compared to what they were, but it's still a helluvalot of money.
Of course there's alot of cheating and skimping, but that's only part of the problem. I'm not entirely sure what the english terminology is here, but the main causes of damage, in no particular order, are:
  • Faulty installation of the waterproofing
  • Insufficient vapor diffusion resistance in the waterproofing
  • Insufficient waterproofing of punctures in the waterproofing made during or after fixing of tiles or sanitary wares
  • Faulty installation of plumbing resulting in failiure and water leaks, often for an extended period of time
The first, third and fourth points are being addressed with increased training, and greater demands on tilers/plumbers who wish to qualify for a wetroom license (domestic bathrooms are classified as wetrooms over here), or a plumbing licence. The waterproofing/plumbing systems are also being modified accordingly.
The second point is being addressed through increased demands on the waterproofing manufacturers. Waterproofing needs to be both water and vapor diffusion proof now. This excludes almost all roll on systems, unless they used in combination with water and vapor diffusion proof membranes. The reason for this is that the water vapor which does get through the waterproofing, even very little, is likely to cause mold growth.
The use of gypsum based board materials isn't permitted in bathrooms any more. The use of wood based substrates has been prohibited for many years.
The materials needed to waterproof an average bathroom today, costs in the region of £400-500, compared to £200-300 just six months ago.
tanking - why?!
Unregistered,
sWe,
Unregistered,
sWe,
