Discuss Techniques for checking levels for a floor in the British & UK Tiling Forum area at TilersForums.com.
monty
What is the best technique for checking levels for a floor?
Is it to place a block of wood on the floor to represent the thickness of your tile and bed.Place a straight edge on the block (or on the surface of an adjacent floor if that is what you are working from).
Pack up the other end of the straight edge with pieces of wood until, by using your spirit level, you know that it is dead level.
By measuring down from the underside of your straight edge to the top of the concrete you will be able to see what thickness you have for your floor.
Repeat this process all around the room.
Or is there a better or easier way?
Monty
GazTech
Monty
Its a good method Monty, cut a tile into inch peices and go from high spot , spot them in place at random intervals , this will show you the levels and give a good datum point when tiling, check your level across different tile pieces to make sure you are level with each tile you fix down.....Gaz
GazTech
you could always ping a datum line around the room and measure down to the floor at intervals to find the highest and lowest points of the floor, then dot your 1st tile at the highest point..
Good point Ed, this will give you high points at the perimeter, you can then determine from there moving in towards the centre.......Gaz. Failing that...flood the room and use measuring stick, take the shallow end as high spot...pmsl
Reply to Techniques for checking levels for a floor in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I’ve a fairly basic question I thinks, hope someone can help me out with. I’m...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
