Discuss The best primer and Adhesive for anhydrite screed in the Australia Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Use an anhydrite compatible adhesive. Here's a list of manufacturers, although it's not exhaustive, and the primer from the same manufacturer to fix the ditra. On top of it you can use your usual flexible cement based adhesive. Also a flowchart that helps you ensure all the steps are followed
Broken Link Removed
[DLMURL]http://gypsol.co.uk/media/1170/guide-sheet-4-flooring-flowchart.pdf[/DLMURL]
Don't forget you might need a movement joint or two in an area that big.
ring me if you need any other advice 07966651006
Stef
Meant to say, it's funny how quick you get used to these screeds.
Looked at a job last week, 4 floors, 2 downstairs on top of a Gyvlon screed.
Speaking to the builder & he was convinced it was a cement based screed till I showed him what needs done to it.
I think he was a but dubious what I was telling him, got a phone call a few days later to say that everything I had told him was exactly what the screed guy told him.
Only problem I picked up was that the screed guy told him it was 1mm per day drying time, I had to explain that that information only goes to 40mm then it's 1mm every 2 days.
Ajax123
1,213
Lincolnshire
You will rarely see movement joints in anhydrite. However if the tile face needs a joint e.g. Large bays, door thresholds, etc this these should be installed regardless of whether or not you see a joint in the screed. Sometimes the joints are not required in the screed and sometimes they are just beneath the surface of the screed so you can't see them. Not ideal I know but it is the best way for the screeders.
Sean SML Tiling
When separating the floors in bays is it ok to use a 3mm Silicon joint as a movement joint?
Ajax123
1,213
Lincolnshire
Yes that's ok provided the floor doesn't expand by. More than about 2mm. Movement joints though are usually 5mm in my experience
Reply to The best primer and Adhesive for anhydrite screed in the Australia Tiling Forum area at TilersForums.com
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
