They are only mitres?! eh?!?!
Aghh I couldn't resist I've put a bin in on that saw on ebay
Do I need a special blade to cut from or will the blade supplied with the machine
I bought the Evolution chop saw, but found the blade too coarse and was catching the edge of the trim, flicking it all over the place. Without a decent clamp it was an eye op waiting to happen.
Boxed it back up and returned it.
A pal of mine uses his all the time and loves it, and for now still has sight out of both eyes.
I'll stick with the Quansol.
U can use a bit of 2by1 to hold the trim down or trap.it under and just cut through the trim and wood and keep ur eyes haha
To be fair, if I sorted a jig to hold the trims it would work fine. My first and second attempt at cutting both nearly ended in an A+E appointment, so was put to rest as a bad idea, and told myself not to be so lazy.
I've just got a proxxon g85 I think it's calls that has a built in clamp
dynamictiling,
Fraser Tiling,
dynamictiling,
Fraser Tiling,
