Three tiles have fell off, how do i refix them?
It's fine don't worry about it.
Shall I close the thread now? I assume the problem is sorted. We always close threads here once the problem is sorted and the Gypsum is fine.
no dont close ther thread please i put another question and picture in this thread, see my previous post to this with pic with red arrow. thanks
one more question sorry, how would i grout this bit, would i need tile grout and caulk and if so, how long would i leave grout before applying caulk, and what type of caulk would i need? thanks
Any you find in your local B&Q is fine usually.
You have to make sure when you hold that stuff, that you hold it the same as in the picture on the tube, else it sometimes doesn't work. Did you hold it right when you did it?
What do you mean, it doesn't work. I used a gun, cos the container was one with a gun. it was hard work and only came out in a thin line.
How do I grout the edges, see pic with red arrow on above?
Do I need to seal edge with anything else as well as grout?
I can't see a red arrow.
the red arrow is on the edge.
I dunno how to grout that bit, and i dunno if i need anything else on top to seal it.
the bottom tile closest to worktop didnt fall off so i cant use beading.
that page directed me to skimlinks, if I just grout it will it be ok, i cant use tile trim cos there is a tile that didn come off, at the botttom.
When you asked if i held it right, i didn't
what do you mean when you said it won't work?
I used a mastic gun and just put a thin circle in the centre of the tile so evo wouldnt squeeze out of the edges.
How would i grout the edges, considering i cannot use a tile trim?
here is where i was redirected http://go.redirectingat.com/?rdrflb=1
thanks
DIY Tiling Forum
female_novice,
female_novice,
