Discuss tile around windows in the British & UK Tiling Forum area at TilersForums.com.
charlie1
Hi all,
I find tiling around window recesses very nerv racking and slow and was just wondering what methods all you guys use.
The method i was shown at Nett seems to work ok but i was just curious to see what other way's there are to do it.
I build two colums around the window then bridge the gap at the top. Then with my level i make sure its all square. I then measure the distances to the hieghest points on the two sides top and botttom and cut all tiles to the same size, ensurine this will square off the window. I then do all the strieght cuts first then do all the corners and then insert the trim. Then i do the recess.
Bobs your mothers brother.
I make this all sound really easy but in reallity i find it by far the hardest aspect of any tiling.
Is there anything you guys would improve on here.
DHTiling
When the tiling goes above a window , fix a temporary batten to support the first whole row above rather than fixing the cut tiles first. It is a lot easier to cut these tiles into place when the surrounding whole tiles have been fixed and have set.
Over a window, the cut tiles will have nothing underneath them to stop them sliding down the wall. Once positioned, use masking tape to attach them to a previously fixed tile to hold them in place until the adhesive dries.
.........dave..
F
felix
.........dave..
Thats the way I do it. It is still time cosuming but I find it accurate
Reply to tile around windows in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
tile around windows
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
