tile around windows
C
charlie1
Hi all,
I find tiling around window recesses very nerv racking and slow and was just wondering what methods all you guys use.
The method i was shown at Nett seems to work ok but i was just curious to see what other way's there are to do it.
I build two colums around the window then bridge the gap at the top. Then with my level i make sure its all square. I then measure the distances to the hieghest points on the two sides top and botttom and cut all tiles to the same size, ensurine this will square off the window. I then do all the strieght cuts first then do all the corners and then insert the trim. Then i do the recess.
Bobs your mothers brother.
I make this all sound really easy but in reallity i find it by far the hardest aspect of any tiling.
Is there anything you guys would improve on here.
When the tiling goes above a window , fix a temporary batten to support the first whole row above rather than fixing the cut tiles first. It is a lot easier to cut these tiles into place when the surrounding whole tiles have been fixed and have set.
Over a window, the cut tiles will have nothing underneath them to stop them sliding down the wall. Once positioned, use masking tape to attach them to a previously fixed tile to hold them in place until the adhesive dries.
.........dave..
.........dave..
Thats the way I do it. It is still time cosuming but I find it accurate
tile around windows
Tags Tags
tile usa
charlie1,
DHTiling,
charlie1,
DHTiling,
