Pompey Monkey
Hi,
I'm tiling a "wet" area around my shower tray but I'm having a real problem cutting the 330mm ceramic tiles.
Every time I try to snap a tile, the break veers off away to the side - And it's always the same side!
I started off with a wickes tile cutter - the first twenty or so snapped fine, and then I went through a whole box with the snap veering off in the same direction at more or less the same place. I didn't know if it was my technique or the cheap tool so I went an bought a Rubi Pocket 50
Initially the Rubi was a pleasure to use! light scoring and a perfect snap every time! But after about twenty cuts, the exact same problem is happening. The frustration is unbelieveable! :yikes:
Is it me? is it the cheap wickes tiles? is the cutting wheel wearing out?
The fact that the symptom is the same every time seems to discount the tiles being the cause and I would guess that a cutting wheel should be good for more than a couple of dozen tiles! So that leaves it down to me being the problem!
I have watched several online videos, but have not seen this issue being mentioned. Help me please!
