Daz
Hi Daz
Right i have scraped nearly all of the adhesive away and when i lay a dry tile it sits 2-3mm lower than the surrounding tile. Is this sufficient? Would i need to prime the area?
Do you offer your services in Norfolk as i may give in and pay to have the work finished off as i can't spend another day removing tile adhesive LOL.
Neil
If the tile is sitting 2 to 3mm lower then you'll be fine. The adhesive will give you a couple of mm so the tile should sit pretty good (you may need to bed it up a tad).
Norfolk is a bit too far for me, but if you really do want to get a professional tiler to quote to finish it, then send Dave a pm and he should be able to sort someone out for you.
