Discuss Tile Movement when adhesive setting? in the British & UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
has someone "vandalised" the work?
only reason I ask is that I has a case I was involved in a while ago where the flooring contractor had laid vynil coverings and the following day when he came back they were all rucked up as if they had not stuck. I was called in to have a look as it was on my screed. Some savvy investigation led me to the conclusion that the client had been in overnight and pulled the coverings up. His reason was never exactly clear but I felt that he beleived that if he complained he would be able to get the flooring contractor to replace the floors and get it all for free.....call me a synic if you like but the construction industry is full of rum characters.....
DHTiling
Mix was a good thick mix not to wet and i just cant understand it.
If you use an adhesive bed that is above the recommended thickness then the adhesive can shrink as it dries.. this might be the cause of the small lipping.. If you have to bed above the usual 6mm final bed depth then it is wise to use a thick bed adhesive..
garretridge
the same thing happened to me a couple of years ago when i just started out job was fine then next day lips everywere i put it down to wrong trowel depth and mixture was not stiff enough i now try to use same addy i like to mix it a lot stiffer like toothpaste now. Not had that poblem ever again we learn by are mistakes and how not to go there again!:thumbsup:
michaelb4348
I have never had a problem until this adhesive which is one i have never used befor and will never use again.:incazzato:
Reply to Tile Movement when adhesive setting? in the British & UK Tiling Forum area at TilersForums.com
    • Friendly
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
