Ricshaw
Hi guys, would appreciate some help:
I'm going to be doing a complete bathroom, floor and walls in ceramic tiles, the walls in large format 300x600 and floor in wood effect 90cm "planks". The existing tiles are very solidly attached and the sills etc allow for tile on tile so I'm going that route though I know the advice is to remove the existing tiles first !
The existing wall tiles (20x20cm) have a semi shine so I will go over with a sander or grinder to key them first.
Can somebody please advise on tile primer brands/types for wall and floor and then what adhesive types I should use for walls and floor. I understand I should use powdered adhesive so the brand types would be useful so I get it right!
Just to make it more complex there will be a strip on the wall of stone effect tiles (also 300 x 600) in Gres/stoneware, does this need different adhesive ?
Any advice you can give would be great, thanks in advance.
