Tile On Tile Adhesive Advice.
I wouldn't tile on tile on walls unless I really had no option and the circumstances were right. I wouldn't tile on tile on a wood floor either.
I went to check a job out the other day prior to starting it and I was greeted with tiled walls which they wanted me to tile on, when I looked closer, they had been stuck onto floral wallpaper! Madness. I walked and some other tiler went ahead with it.
thanks a lot for this, point well taken, I suppose I'll have to spend the extra time removing them and making good, it's really time that is the problem.
I'll still tile over the tiles on the floor, any specific adhesive for this or is Keraflex ok after I prime them ?
On another note is the standard 180mm diamond disc that comes with the Vitrex 750 Pro cutter suitable for gres/stoneware as well as ceramic tiles ?
The extra time will save you extra £'s in the longrun.
The eco prim grip will be ok to prime the floor. Keraflex also suitable for tiling. Keraquick if you want rapid setting.
Ricshaw,
Tile Shop,
Ricshaw,
Tile Shop,
