Tile spacers
i use my spacers as wedges with ceramics on walls, the further you push them in the wider the joint. I keep an eye on my vertical joint consistency to keep lined up and a 1.8 level on top of each course for final check. A dodgy off square tile will throw you out anyway and the quality of some ceramics means constant adjustments.
Snap Mark, you just beat me, must be my age.:thumbsup:
Just ticking over Mark, not breaking any records. Glad to hear you are busy mate.:thumbsup:
Only use spacers on heavy tiles if the tiles hold up I dont use spacers if I do I always remove them and use again never use spacers on floors just do it by eye.If the tiles are bad quality and different sizes I tend use a few wedges to get them back level.
i usualy use 2mm peg spacers but the last cpl of months i have been usen nicobonds 2mm cross spacers and there pretty good i normaly use them as pegs but there are times were i just jam them in the corners and push them in, coz i need to grout instantly after tiling a kitchen on this job so there quite handy
I always remove spacers. I use cross spacers as pegs and pull them out when I'm giving tiles a buff up before grouting. I've seen too many tiling jobs where spacers have been left in and you can see them through the grout.
I just use the B&Q ones there only cheap so just sweep them up and thrown them in the bin after I've pulled them out.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
