Tile spacers
it depends what tiles im using,natural stone/slate not very often if at all,ceramics and porca sometimes i do,sometimes i don't,like most depending on sizing of tiles
Spacers should be left in if used .wedges are useless in my experience they can throw a wall or floor out in no time, in my experience lash clips may give a flat floor but how do you deal with hollow points,we can all talk about what methods work for each of us its what works best for you personally.
i use my spacers as wedges with ceramics on walls, the further you push them in the wider the joint. I keep an eye on my vertical joint consistency to keep lined up and a 1.8 level on top of each course for final check. A dodgy off square tile will throw you out anyway and the quality of some ceramics means constant adjustments.
I agree about the lash clips Mike, but I use the Rubi wedges, they tend not to slip like some do. I only use them on walls for joints 2mm/3mm, I find if there is a bit of size in the tile then by pushing or puliing the wedge I can fine tune the joints as I go. But as you say each to their own, How you doin by the way ? long time no see mate, hope you are keeping well.:thumbsup:
Only time i use spacers fully inserted is tiles smaller than or equal to 6x6's, i tile in 4 x 4 sections then pull them all square with my 600 level... Just as Darren at nett taught me!
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
