Guest viewing is limited
Discuss Tile spacing in the UK Tiling Forum area at TilersForums.com.
E
easyt
Advice sought. I am due to lay some floor tiles (310 x 310 ceramic) on a cement screed sub base. What tile spacing would you recommend. I thought 4mm. Could I go less or should I go more. Any views ??
Similarly I am going to put up some 250 x 335 ceramic wall tiles. These will be on a variety of substrates (sand cement render, plasterboard and aquapanel. I thought 3mm. Could I go less or should I go more. Any views ??
EasyT
Pebbs
Some Architects have a crazy idea that a 1mm joint is the answer to everything. When in fact it opens up a can of worms when the stone starts to crack. 600x600mm stone can run out by 3mm and that is the tolerance. Unless he had them water cut, there is no way they will be running in at a perfect 600x600mm. I spend hours trying to explain movement and expansion joints, before the specification is drawn up. Where they are insisting on 1mm joints 99% of the time it all ends in tears, and the Stone Federation are called in to repeat what I'd told them 2 years before.
Pebbs
Reply to Tile spacing in the UK Tiling Forum area at TilersForums.com
    • Friendly
Tile spacing
