White Room
There's been a fair bit of debate on this one, So I phoned British Gypsum and spoke to there tech line, Is as follows;
They reccomend that you don't tile directly to standard plasterboard, Should be skimmed first. 20kg
Moisture resistant board can be tiled onto directly at 32kg
Float and set is 20kg
I'm sure this will cause some discussion, Tiling direct onto plasterboard was the one that surprised me
Rang BG again about the standard board and had a different answer, Would be ok in a dry or small area to tile onto. Thats from two different techi's:mad2: Just trying to get the facts right
